System Exec always runs minimized?
I am running a labview code that runs a python script via the "system exec.vi".  I want the user to see the command prompt as the code runs.  This VI has input for "Run Minimized?", but it does not seem to work.  The script I am running takes a considerable amount of time to run and the command prompt actually gives an indication of how much time is remaining.  Is there a way for the command prompt to be displayed as the code is running?
Thanks.
(2,979 Views)
Did you also Wait until completed? you might need admin privledges
"Should be" isn't "Is" -Jay
(2,971 Views)
I do have wait until completed on and I am an admin.
(2,946 Views)
When I use system exec and set "run minimized" to False, the screen appears.
LV8.6
Windows7
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,927 Views)
Accepted by asdlkfjalskdjf
We will probably need to see some code.  enclude the py as txt
(2,925 Views)
