‎02-12-2013 06:16 PM
I am running a labview code that runs a python script via the "system exec.vi". I want the user to see the command prompt as the code runs. This VI has input for "Run Minimized?", but it does not seem to work. The script I am running takes a considerable amount of time to run and the command prompt actually gives an indication of how much time is remaining. Is there a way for the command prompt to be displayed as the code is running?
Thanks.
‎02-12-2013 06:36 PM - edited ‎02-12-2013 06:45 PM
Did you also Wait until completed? you might need admin privledges
‎02-13-2013 08:35 AM
I do have wait until completed on and I am an admin.
‎02-13-2013 10:01 AM
When I use system exec and set "run minimized" to False, the screen appears.
LV8.6
Windows7
‎02-13-2013 10:05 AM
We will probably need to see some code. enclude the py as txt
