Synchronizing data acquisition with NI 9220 and 9234
Glad you finally figured it out. I should have posted the VI much sooner, would have saved you a lot of headaches and time. Good luck with the FPGA, it can be frustrating at times, especially the long compile times.
cheers,
mcduff
Message 31 of 32
(853 Views)
Hi, sorry for bothering you again.
I optimized the code a bit and now it's compiling and running fine.
EXCEPT: I ran into a problem with the FIFOs -.-' Could you maybe take a short look at the new forum post i created? I did not want to stretch this post here out to far...
https://forums.ni.com/t5/LabVIEW/FIFO-missing-data/td-p/3919792
Message 32 of 32
(845 Views)
