String Functions Used for Password creation
I want to create a string used to input a password. In that I want to put some conditions like follows:
1. String must not me greater than 8 characters.
2. It must contain atleast one Upper case and one Lower case character.
3. It must contain atleast one symbol.
For this i didn't find any direct function so I have completed the program halfway.
Please, see the attahed VI and give some solution if anyone have.
Message 1 of 11
(6,841 Views)
You only attached the project file, no VIs.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 11
(6,827 Views)
Accepted by PoojaMadane
Match Pattern will be your friend here.
Message 3 of 11
(6,821 Views)
Hi Pooja,
1. StringLength function…
2. LexicalClass function
3. first define "symbol", then use LexicalClass or some kind of LUT (LookUpTable)
Message 4 of 11
(6,817 Views)
Try this.
Message 5 of 11
(6,787 Views)
Sorry. Here, is the project file.
Message 6 of 11
(6,764 Views)
Its a really good solution. And you made it too simple.
Thank you.
Message 7 of 11
(6,760 Views)
This might just be wanting to optimize things as much as possible, but instead of using pattern matching for the upper and lower case comparison could you not just compare the inputs and outputs after passing the string through "To Upper Case".
Message 8 of 11
(6,754 Views)
No, it is not enough. Strings with only lower case letters will pass.
Message 9 of 11
(6,739 Views)
With this solution I want to add some extra points for my project.
1. I want to display a pop-up window if any of the match pattern becomes false.
For this, I have used one button dialogue and showing "string limit exceeded" pop-up.
But, for other conditions like I want to show "There must be atleast one capital letter." for second match pattern function.
Its is malfuntioning in my VI.
Please, give the solution if any.
Message 10 of 11
(6,727 Views)
