em 10-16-2020 01:37 PM
Hi all, I just installed LabVIEW on a new laptop, and I cannot use Small Fonts in the icon editor. I've tried to install the font file, and I can see it in "C:\windows\fonts". However, in LabVIEW when I type text into the icon editor, it's still using several colors to try to make a black font. If I select a different font, I cannot get back to Small Fonts because it's not in the dropdown menu. (I have to edit the ini file). Any suggestions?
Using: LabVIEW 2016 (32-bit), Windows 10 (64-bit)
em 10-16-2020 01:46 PM
em 10-16-2020 03:05 PM
10-16-2020 05:03 PM - editado 10-16-2020 05:04 PM
Edit: I totally misunderstood the question.
em 10-22-2020 01:05 PM
I reinstalled the Small Fonts file from another PC at work. Previously I got the file from a forums post. I also ran the NI updates.
Now I can use Small Fonts in the icon editor! But, if I switch to another font I cannot get back to it. I have to go into the .ini file and set:
IconEditor.TextTab.TextFont="Small Fonts"
Still kind of annoying, but at least it's workable now.
em 08-24-2021 02:50 PM
Same problem now with LV2020. Few versions ago I have copied Small Fonts from older PC and it works. It seems I have to do this once more as only I will find an old PC with LV.
em 08-17-2023 02:50 AM
Hej, did you solved this problem? For me seems like nothing happens.
I tried to reinstall Small Fonts, edit config, chang region, but I sill can't use Small Fonts in Icon Editor.
LV2020
em 08-17-2023 08:47 AM
Just don't use text in your icons.
em 11-14-2023 08:33 AM
I solved it finaly. I download Fonts Pack for Win10 from this link, https://www.w7df.com, and tried several Small Fonts from the pack.
Hope one of this Fonts will help.
