Simplest method in finding a Numeric Palindrome
@Ben wrote:
Can it be done using a regular expression?
Probably, but not with only two functions.
Starting from a numeric, we first need to format into string, followed by the suitable regex (not sure how). Then we need to convert the output into a boolean. Still three functions. 😄
Message 21 of 44
(2,950 Views)
The loop was just to set a random selection on numeric range limit.
And, I was cautious on the number limit too, christian. As far this default value
exceeds the I32 control both in numeric control and Array control works fine.
Message 22 of 44
(2,939 Views)
Actually, it is possible Ben.. with logarithmic and all math concepts involved. And in that case too, it goes different with odd and even palindrome's.. It's definitely, good to think as we are doing now.. Logically!!
@Ben wrote:
While not my area of expertise...
Moreover, am thinking of a solution that wouldn't involve Numeric to decimal string conversion function. Cause, that's the only method to use only 2 functions in place of 3 as I have mentioned in Topic at first. Lets see..
Message 23 of 44
(2,938 Views)
Exercise artistic liberty and define that the number be entered as a string.
Ben
Message 24 of 44
(2,936 Views)
Accepted by PriyadarsiniS
The solution goes something like this.. Am just thinking other possible sol. too, to just iterate the claim Smiley Wink
As in place of 3 functions, we reduce them to 2 functions by removing decimal string conversion and using the NumericText. Text property node. Thereby, taking string form of a number from itself!!
Message 25 of 44
(2,931 Views)
That is still three function, one being a very expensive property node! Make the input a string and get it over with. As a bonus, it will work with almost any number of digits and even detects in any random text string is palindromic at the same time.
As long as you only enter numeric characters, there is no difference to the other code.
Message 26 of 44
(2,933 Views)
2 functions (1 p-node)
Spoiler
"Should be" isn't "Is" -Jay
Message 27 of 44
(2,933 Views)
Yup, Ben.. this was the first thought that came into picture.
Instead, of all this logical method of analyzing we just just straight away make the user right in a string control with artistic liberty, with some limitations written on the *terms and conditions view. Smiley Very Happy
Better an oops than a what if.. Smiley Wink
Message 28 of 44
(2,927 Views)
Spoiler
If am not mentioning it wrongly..
Why was it named Spoiler ?! Smiley Surprised
Message 29 of 44
(2,922 Views)
OK So Great minds think alike
(Interesting cross-post)
How about 1 primitive? no fair peeking.......
Spoiler
Message 30 of 44
(2,917 Views)
