07-31-2009 07:47 AM
Hi everybody,
I am using shared variable in one of my project to communicate between RT program and my PC program. FOr very first time I run the program in my PC. I am facing the error 1967362044. Can anyone tell the reason for this error and solution to get rid of this error. I have also searched in ni.com but I didnt find any solution regarding this. So, I request you to provide me a solution.
Thanks and Regards
Giridhar
Idesign
07-31-2009 08:25 AM - edited 07-31-2009 08:25 AM
Hi Giridhar
From what I've seen this error can occur if the connection between computer and target was suddenly lost while the shared varible was written to. In that case rebuild the shared Variable.
Another instance were this can occur is if the project was developed on a computer with a localized version (i.e. non-english) version of Windows AND LabVIEW. Is that the case for you?
Best Regards
David
NISW
07-13-2010 06:57 AM
I got the same problem.
I use LabView as english-version and the project I want to use is developed in LabView as german-version.
Is there a simple workaround to fix the problem?
regards,
Sven
09-15-2020 05:21 PM
I'm having the same error. However, I'm using the Shared Variables within the same project on a PC. I'm trying to manually deploy the library of Shared Variables. I'm using LabVIEW 2016 on Window 10.
