Script Error when click on Find Example in LabVIEW Help
Great detective work. Maybe MS, not NI needs to fix this, maybe with another windows update..... 🙂
(The article mentions an update to scripting ...)
Message 21 of 69
(3,815 Views)
Additional note...
I do not see the problem running Windows 7...
and I only apply updates when forced to do so.
Ben
Message 22 of 69
(3,809 Views)
Ben, are you fully updated? Billko above saw it in W7.
Message 23 of 69
(3,804 Views)
No Sir!
I only apply updates when there is a reason to do so.
I have seen too many problems when I let updates happen.
Ben
Message 24 of 69
(3,802 Views)
... such as this one 😄
Message 25 of 69
(3,798 Views)
@ToKa1971 wrote:
As suggested by @altenbach, windows update KB4462919 seems to be the problem:
The only updates I see are: KB4464330, KB4465477. (Depends on what version of windows you are running (Fall, spring update, etc.))
Uninstalling KB4464330 did not fix the problem. Will try a few more things.
Message 26 of 69
(3,792 Views)
https://support.microsoft.com/en-us/help/4462919/windows-10-update-kb4462919
After removing this update from my Windows 10 computer LabVIEW help finally works.
I went and checked this out and saw I had the same problems.  I had a KB 4462918 in my windows update history.  When I removed that one, the problem went away.
The description for 4462918 seems similar to 4462919.
Message 27 of 69
(3,750 Views)
Same problem here, except I don't have 4462918 or 4462919, time to roll back updates one by one....Capture.PNGCapture.PNG
Message 28 of 69
(3,692 Views)
Yes, the exact KB depends on the W10 version you are running. I still hope that Microsoft can do a forward fix. they must be aware of it by now. Breaking a decade+ worth of an installed base of commercial software should force some priority to this. You'd think!
Message 29 of 69
(3,663 Views)
I can confirm the bug definitely happens on WIndows 7 (x64) with the latest updates.
Message 30 of 69
(3,634 Views)
