Screenshot
I need to save a screenshot containing a grapgh and other data indiactors (as shown in the attached figure). Please advise the ioptions available in version 2012 or lower. Thanks in advance
Message 1 of 11
(3,926 Views)
Are you looking for a screenshot of a LabVIEW front panel?
This looks more like the screenshot of an instrument.
Message 2 of 11
(3,912 Views)
An Image Depth of 1 will return a black and white picture.
Message 3 of 11
(3,891 Views)
Yes it's the part of the front pannel. Graph and all the data are captured from a spectrum anlyzer separately. I can save the graph only, but need to include those data too in the image.
Thanks!
Message 4 of 11
(3,875 Views)
How do I choose a part of the front pannel (Do'nt need to include some control buttons of the front pannel)
Thanks!
Message 5 of 11
(3,868 Views)
You could put the controls that you want into a tab control. I've attached an example of this.
An alternative method is to resize the VI such that only the data you want is visible . The constant of Visible Area Only would then need to be set to True.
Message 6 of 11
(3,856 Views)
Also look at the Code Capture Tool.  It is often used on the forums for capturing and posting screenshots (with embedded code).  But it provides a palette that allows you to programmatically take screen captures.
Message 7 of 11
(3,845 Views)
You forgot the link you usually provide.  Unfortunately, I forgot what it was, also.  And there are two community nuggets, one for v1 and one for v2.
Bill
CLD
(Mid-Level minion.)
Message 8 of 11
(3,812 Views)
You're right.  I just didn't have the time to go dig up the link.  Over the years, how to get to it has changed as new versions came out.  I googled it and found it here.
http://lavag.org/files/file/63-code-capture-tool/
But I think if you download and install VIPM, it will also show up in the list of add-ons you can install.
Message 9 of 11
(3,788 Views)
Thanks NLutz,
That's almost done. Only one problem remaining. In B&W image, Tab FG is black and no labels are visible [I need it in B&W]. Could you please advise how to solve this.
Thanks!
Message 10 of 11
(3,756 Views)
