04-25-2008 09:20 AM
04-25-2008 09:56 AM
Hi Oley Mich,
as far as i know it should be no problem. You can install the Report Generation Toolkit without any Office Tool, but you can´t use the Excel or Word part without installing the corresponding Office Tool.
Mike
04-25-2008 09:59 AM
04-25-2008
10:03 AM
- last edited on
04-19-2026
10:10 PM
by
Content Cleaner
Hi Oley,
now i´m sure. You don´t need the Office Tools on your pc if you don´t use the Office functions. Here is the link to the user guide:
https://www.ni.com/docs/en-US/bundle/373805a/resource/373805a.pdf.
Mike
Message Edited by MikeS81 on 04-25-2008 05:05 PM
04-25-2008 10:13 AM
04-28-2008 10:06 AM
Hey Oley,
I have been doing a bit of research and what I found is that there was a corruption in the Windows Installer database. You can use the "Windows Installer Clean Up Utility" downloaded from Microsoft to remove ALL traces of Office, and then reinstall. This should solve the problem. I found this in another discussion forum with someone else with a very similar issue. I hope this helps!
Carla
