How do I re-enable a device after checking "Device enabled" for VISA port COM1
Hi there,
I just get started with LabVIEW and played around with the functions and settings in MAX. Doing that I hit the 'Device enabled' box for my COM1 device. So now it is disenabled and I cannot make any changes or use it. How can I re-enable it or set it back to default settings? I attached a screenshot, where you can see that the box to enable the device is inactive.
Message 1 of 13
(3,360 Views)
Hi germaica,
i have no problem to disable it and enable it later. Which version of MAX do you use?
Mike
Message 2 of 13
(3,355 Views)
Hi Mike,
I use version 4.1.0.3001 of MAX.
Message 3 of 13
(3,353 Views)
Hi germica,
i tried it with MAX 4.3.
Mike
Message 4 of 13
(3,348 Views)
Do you have any idea how to solve the problem? I tried a few other ways to set the properties but nothing worked. (I have to admit that I have not really a clue of LabVIEW yet, since I'm working with it the third time only. So I probably missed some possiblities.)
Message 5 of 13
(3,345 Views)
Hi germica,
did you restart MAX and tried it again?
Mike
Message 6 of 13
(3,343 Views)
Done that, restarted LabVIEW, restarted the PC, nothing worked...
Message 7 of 13
(3,341 Views)
Hi Germica,
i think there is another problem, because of your question mark. Did you install the driver for your device?
Mike
Message Edited by MikeS81 on 04-28-2008 10:19 AM
Message 8 of 13
(3,334 Views)
Hi Mike,
I want to try to deinstall MAX. Do you know if that is possible without deinstalling labview entirely?
Germica
Message 9 of 13
(3,333 Views)
The driver should be installed, yes!
Message 10 of 13
(3,330 Views)
