Remove Child Window from Parent using WIN API
Hello all,
I am using User32.dll to make a parent-child relationship between two VIs. I use SetParent function, and pass the handle of parent VI and child VI to this function. Now, after this relationship has been established, I want to remove the child window from the parent and use it as a independent VI using WIN API. Can anyone help me on this?
Thanks in advance!
Fragger Fox!
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(8,322 Views)
Accepted by FraggerFox
Hi Fragger Fox,
i think it should be possible if you assign a new parent to the child. Maybe it works if you assign the desktop as new parent.
Hope it helps.
Mike
(8,320 Views)
@MikeS81 wrote:
Hi Fragger Fox,
Hope it helps.
Mike
I am thinking if that would really work. Since the child already has a parent, just giving it a handle of other parent would make it a child of other parent, in this case, the desktop? Would it automatically remove itself from its parent?
Also, how can we get the desktop handle?
Fragger Fox
-FraggerFox!
(8,309 Views)
Hi Fragger Fox,
from the description of the "SetParent" function, i think it will change the parent. You can get the desktop handle with the "GetDesktopWindow" function.
Mike
(8,305 Views)
You should be able to set a NULL handle to undo the parent-child relationship and make the child window again a normal top level window. Setting the desktop as parent is probably not the same as being a top level window.
Rolf Kalbermatter  My Blog
(8,289 Views)
