Relay control via time
Accepted by Chowdhury_Milon
Hi Milon,
I want the relay off permanently after 5 sec.
as has been told before:
open the relay AFTER the loop by sending a FALSE with an additional Write function!
Message 11 of 13
(1,448 Views)
Check the input nodes Elapsed Timer, You can find Auto Reset by default it will be true make it false, if you dont want second iteration. you can make relay off in the False case and come out of the loop.
Message 12 of 13
(1,443 Views)
Message 13 of 13
(1,438 Views)
