Error open VI
Hello all ;
When i try to open vi file this error apparent "LabVIEW: Failed to load dynamic library because of missing external symbols or dependencies, or because of an invalid file format. The file could not be loaded"
Forza Juventus
(3,981 Views)
You have not given us enough information.
  • Has LabVIEW been installed?  What Version?
  • Can you open LabVIEW without errors?
  • Can you run any of the Examples that ship with LabVIEW without errors?
  • What VI file gives you these errors?  You should attach the File (not a picture of it, but the actual file with extension .vi) so we can examine it, test it, and maybe tell you what's missing.
(3,925 Views)
  • Has LabVIEW been installed?  What Version? 16.0
  • Can you open LabVIEW without errors? yes
  • Can you run any of the Examples that ship with LabVIEW without errors? yes
Forza Juventus
(3,907 Views)
Hi moussadjenane,
your "VI" file gives the same "it's no resource file" error message with LabVIEW2011.
LabVIEW even can't detect the LabVIEW version of the VI…
I suspect you did something wrong with the file!
Did you overwrite the file content (partly)?
Did you transfer the file using some weird method (like FTP) with enabled EOL conversion?
Why don't you check out an older version of this VI from your SVN repository?
Or simple get an older backup of the VI?
(3,905 Views)
Looking at the file and comparing it to another VI in Notepad++ it looks like all VIs should end with the file name, which yours doesn't. It's corrupted. You'll need to restore the file from a backup.
/YCorrupt VI.PNG
Qestit Systems
Certified-LabVIEW-Developer
(3,901 Views)
