Relay control via time
Hi everyone,
 I am fairly new to Labview. I want to control pump using Arduino UNO circuit, Relay, and Labview. My assignment is running a pump for a certain period of time like 2 min or 5 min. I tried by using "Elapsed Time" option of LabView but can't turn off the relay after elapsed time.
I have attached my LabView code here. please suggest me for a solution. Thank you for time and assistance in advance.
Message 1 of 13
(6,874 Views)
Hi Milon,
once the time has elapsed you finish your loop and close the connection to the Arduino.
How do you want to control the relay without having a communication to the Arduino?
Message 2 of 13
(6,857 Views)
While it is fine to post pictures of your Arduino board, it is not so helpful to post pictures of your code.  Please post your actual VI (i.e. attach the file that has the extention ".vi").
Message 3 of 13
(6,827 Views)
try inserting a "not" function at the bool output of your timer, connected to your "write".  Smiley Wink
Message 4 of 13
(6,805 Views)
Hello Mr. GerdW,
At first thanks for your quick response. Actually, the relay is connected to Arduino UNO (Powered from Arduino circuit and Digital I/O pin is also connected). I thought If the loop is finished, Arduino circuit along with relay will be closed. but the relay is not closing. Here is the problem....
Message 5 of 13
(6,787 Views)
Hello Mr. Bob_Schor'
Thanks for your quick reply. Here is my VI Code...
Message 6 of 13
(6,786 Views)
Mr. Apok'
Would you explain your suggestion? Apologies, I can't find out that place....
Message 7 of 13
(6,774 Views)
Accepted by topic author Chowdhury_Milon
No need to create 3 messages to reply to different people and attach the same VI twice.
Your VI runs for 5 seconds.  During that time, your relay will open or close each time you press your switch.  Once the time is up, the loop ends.  It will leave the relay in whatever state is was the last time you pressed the button.
If you want to do something when the loop ends, then create another digital write outside the loop that executes before you close the connection.
Message 8 of 13
(6,771 Views)
Try this Method
Message 9 of 13
(6,768 Views)
Hello PalaniveIT,
Thanks for the guidelines. I made a code according to your guideline. but two problems occur 1) after elapsed time (5sec) it starts automatically, 2) It runs for 4 sec, not 5 sec.
Time will be adjusted but I want the relay off permanently after 5 sec. I have attached the code for your verification.
Message 10 of 13
(6,761 Views)
