Reading the number from a certain column in an running .CSV file
Hi GerdW,
The last method for building string array I found that very helpful.
I have tried different cases for decimal correction, it didn't work. can you please tell me, how can I solve this problem?
Message 41 of 80
(2,212 Views)
Hi Shannara,
did you read the LabVIEW help on format codes by now?
%,2f is just WRONG!
Which decimal separator is your OS set to? Do you use the comma as decimal separator?
Which decimal separator is Excel (on your specific computer) expecting?
Does Excel also expect the tab used as delimiter in your CSV files?
Can you attach the text files you created?
Message 42 of 80
(2,210 Views)
In LabVIEW, the delimited separator is set to the localized decimal point and Excel also it is according to Germany which is set to comma as decimal separator.
"%,;" this formats the local delimited separator, right?
Message 43 of 80
(2,207 Views)
Hi Shannara,
Then go with a comma in the numeric data and the tab as delimiter in your text files.
Be warned: whenever you will get in contact with international customers/collaborators you will get into trouble with such TSV files very quickly. I recommend to use the point as decimal separator…
Yes, %,; sets the comma as decimal separator when converting numbers into strings (or vice versa).
But still %,2f is plain wrong…
Message 44 of 80
(2,203 Views)
Message 45 of 80
(2,200 Views)
Hi Shannara,
still not right.
%,; just specifies to use the comma as decimal separator, but there is no information on how to format the floating point number!
Use %,;%.3f - and read the LabVIEW help on formatting codes again!
Message 46 of 80
(2,205 Views)
HI GerdW,
Sorry for disturbing you, I still didn't get the solution for it. I have got the values like this.Unbenannt.PNGUnbenannt.PNG
Message 47 of 80
(2,202 Views)
Is it possible, the timestamp can be converted into array format?
Message 48 of 80
(2,193 Views)
Hi Shannara,
how often have I told you by now that %,2f (or %,3f) is plain wrong for a format code!?
Again: read the LabVIEW help on format codes!
Try this even more simple code:
(When the numbers already are converted to strings then it doesn't make sense to use a numeric format code for WriteDelimitedFile…)
Why do you need this?
And how should the array look like?
Message 49 of 80
(2,182 Views)
I mean, not in the string array format, I mean it should be like a Unbenannt.PNGnumerical array format.
In this code format, it is saving the data as I need, the problem is with the timestamp, How can I convert time stamp in the numerical array format?
Message 50 of 80
(2,176 Views)
