09-17-2020 08:46 AM
Dear RTSLVU,
I am using Agilent 34972a with 3 multiplexer cards which are 34901a. I am measuring 2 different types of measurements.
Measurement 1:
I am using only 10 channels for days of measurements and there I don't have any problem.
Measurement 2:
I am using 50 channels here for the measurements and here I am always having a problem which is visa timeout operation before completion and it stops my data acquisition after 10 hours or 15 hours. I have to acquire the data for days of measurements.
can anyone tell me, how to solve this problem?
09-17-2020 09:36 AM
What interface are you using on the 34972A? USB or Ethernet?
I have found the USB interface to be flaky on the 34972A units and recommend using the Ethernet (LXI) interface exclusively.
09-17-2020 10:25 AM
I am using the USB Interface?
09-17-2020 10:53 AM
As I said I have had random timeout error problems using the USB interface.
Try using the Ethernet interface.
09-18-2020 07:01 AM
If I use Ethernet Interface, Do I have to change code?
How can I integrate an Ethernet connection, Do I need to have an Ethernet hub?
09-18-2020 09:27 AM - edited 09-18-2020 09:28 AM
Well if your program is written correctly, such as having the end user search for and/or select the instrument at startup or if it's missing then you shouldn't have to change anything.
But if your VISA Resources are hard codded then yes, you will have to change some code.
Hub or no hub depends on your setup. If your computer has to be connected to a local network then you will need a hub and it complicates everything.
But if you just need to connect the computer to the instrument you will not need a hub, but you will need to set a static IP address on both devices.
After you set that up you will have to open up NI-MAX and create a new VISA Resource, Alias, etc. for the data logger on Ethernet (New Network device) Just follow the prompts it's pretty self-explanatory.
Once you have the new VISA Resource created you will have to change any VISA resources in your coed that are hard coded to use the USB port to use the new VISA Resource you created.
09-21-2020 07:24 AM
Hey RTSLVU,
I am using a PXM359-3.5G10V pressure transducer, it gives me the voltage output 0-10V for 0-3.5bar, it is for measuring the internal pressure of a cell, while charging my battery it is giving me the positive excitation signal, and while discharging it is giving me the negative excitation voltage signal.
May I know why the polarity is changing here?
09-21-2020 11:47 AM
Sorry, I have never used that type of sensor.
09-22-2020 04:07 AM
Hi Shannara,
Have you read the datasheet?
Those "excitation" pins are used for power supply of the sensor for this 0-10V output model.
You need to supply 15-30V on those pins/wires - without changing polarity!
09-22-2020 04:38 AM
Hi RTSLVU,
No problem, thank you so much for the answer.
