01-19-2007 10:14 AM
01-19-2007 11:35 AM
Sorry, I am unclear what you mean by "assitant". Are you talking about the express VI?
In any case, reading a comma delimited file is pretty simple, just use the plain file I/O finctions and set the access options as desired.
01-19-2007 11:50 AM
Thanks for the reply. Yes, the assistant. I'm just learning so I'm not sure how to easily use the read from spreadsheet file to create a waveform (first column is time, no headers). The options with the assistant were perect for this. Can I change this to the file read command without too much work?
01-19-2007 11:58 AM
Sorry, meant yes the Express VI.
01-19-2007 12:11 PM
01-19-2007 12:29 PM
01-22-2007 12:13 PM
