Reading from the specific binary file
Hallo,
I received binary file with specific format and I need to read images from this file, but I have no idea how to do it.
In this binary, images from the camera and settings are saved. I need to read just the images and time between them. I don't know how to extract this.
Thank you very much for your help.
There is a binary stucture.
Saving images *.bvg
Head of file (1024 bytes)
            Size of the head file : U32
            Size of the head of the image :U32
            Size od the picture with head: U32
            Number of images: U32
            x-size of images, in pixels: U32
            y-size of images, in pixels: U32
Type of the images: U32
            0….Grayscale(U8)
            1….Grayscale(I16)
            2….Grayscale(SGL)
            3….Complex(CSG)
            4….RGB(U36)
            5….HSL(U8)
            6….RGB(U64)
Time of the picture taking:
·         Length of the string: U32
·         String (day.month.year   hours:minutes:seconds)
Camera settings:
·         Exposure: U32
·         Binning: U32
·         ROI X: U32
·         ROI Y: U32
·         ROI Width: U32
·         ROI Height: U32
·         Bit depth: U32
·         Colour: U32
0….Grayscale
1….RGB
Head of the image (128 bytes):
            Time from the previous image, in seconds: DBL
Image:
            x-axis size of image: U32
            y-axis size of image: U32
            matrix of intensity: it depands on image type
(3,309 Views)
This does not seem very difficult. Just read the file as one big string, then typcast the parts according to the pattern given.
(One complication could be byte order. Do you know if the file is big endian or little endian?)
Can you attach a typical file so we can try? 🙂
(3,300 Views)
It is "native, host order".
There is the file
http://fry.mstu.cz/pic.bvg
I cannot upload it, it is too big (5.27MB)
(3,292 Views)
OK, what is your LabVIEW version? For pre-8.0 you need to do the byte spwapping manually, while newer versions have it built-in as an option for the file read and flatten/unflatten tools, etc.
Attached is a very simple example that should point you in the right direction and get you going (LabVIEW 8.0). Modify as needed.
I read the 1024 byte header as U32 array, then read the 128 byte image header, then read the first image frame using the sizes from the header and the image type from the example file (U8 greyscale). Many additions are needed to e.g. automatically deal with different image types, etc.
(3,266 Views)
Thank you very much for your help, now I understand how it works.
Tomas
(3,212 Views)
