Read values on text file
Hello I would like to read the values from the treatment of a first VI in a second. The data was saved from the text file I can not do it, I try the process in vi I send it to you.
Here is the capture of the text file and the data I want to read.
(4,643 Views)
  1. Read the entire text file into an array using "Read Delimited Spreadsheet.vi"
  2. Using the Array functions index the data you need out of the array
  3. Using the String to number function convert the string numbers to numeric data types
=== Engineer Ambiguously ===
(4,620 Views)
I would like to save the values in a TDMS file in a first vi and read the values back into a second, but the Vi me always generates errors. Can I have an example that I could use to realize my function ..?
Thank you
(4,597 Views)
Hi Ernest,
Just attach your VI(s) so we can tell you why that error occurs!
(4,595 Views)
Hello thanks for your help, the vi does not generate an error but does not read the value at the line and and the chosen column. I inserted the two codes on a same vi of tests to observe the operation.
But I do not get anything results.
I need help or need a code that can perform my task.
Thank you
(4,581 Views)
Thank you
Perhaps the file is empty the first time?
Also, why update the values on events that seem totally unrelated?
The code doesn't reflect the problem you described. Either the code is way to complex, or you didn't tell us properly what you want to do.
(4,572 Views)
In fact I could have some code vi but I can not read. Do you have a vi that can solve my problem?
A vi that reads the values saved in a text file according to the desired rows and columns.
Thank you
(4,562 Views)
