Basic Averaged DC-RMS for N Chan
I need to use the Basic Average DC-RMS for N Chan to process my signal. However I have the base version of labview and this function is not available. I am looking for an option of a subVI to do the same but using functions available in base version of Labview.
Any help would be highly appreciated.
(3,268 Views)
What do you think "Basic Averaged DC-RMS for N Chan" does?  Sounds like it has N Channels of data (maybe "rows in an array" where there are a certain number of samples/row (maybe individual elements of these arrays).  I wonder what "Averaged DC" might mean?  And what does "RMS" stand for?  If I knew that, could I compute it?
Have you ever taken an Engineering course where you talked about signals, sampled at equally-spaced intervals and giving you an array of values?  If you don't know these very common terms, you could "look it up" (try the Web).
(3,243 Views)
It receives a DC Voltage signal and the output is the RMS (root mean square) voltage value.
I attached my VI, i need to change the DC to RMS Voltage box to something I can handle with the base version og labview.
(3,213 Views)
It is really too bad that NI puts the Dreaded DAQ Assistant, which uses the confusing "non-LabVIEW" Dynamic Data Wire, in such a prominent place that tricks LabVIEW neophytes into using them.  I made one change -- I changed the Dynamic Data Wire to a much-easier DAQmx-like 1D Array of Waveforms.  With this, a single For loop, and two Index Array functions (only one of which I put in this Snippet), you can get the 7 DC indicators (shown) and the 7 RMS indicators (left as a trivial exercise for the Reader).  I delete the rest of your code from this Snippet ...Banish the Dynamic Data WireBanish the Dynamic Data Wire
(3,206 Views)
