07-06-2016 08:04 AM
Hi everyone
I've set up a RT-Controller (8108) in a PXIe-Chassis (1078). Additionally I've installed the latest DAQmx-Drivers on my Host and my RT-System. Unfortunately I cannot import any DAQmx-Settings from NI MAX nor can I create a new Tast in my Programm. If I click "new DAQmx task" nothing happens, not even an error appears.
Does someone have experience on that?
Thanks a lot 🙂
B.
07-06-2016 08:10 AM
@sciu wrote:I've set up a RT-Controller (8108) in a PXIe-Chassis (1078). Additionally I've installed the latest DAQmx-Drivers on my Host and my RT-System. Unfortunately I cannot import any DAQmx-Settings from NI MAX nor can I create a new Tast in my Programm. If I click "new DAQmx task" nothing happens, not even an error appears.
Yes (although I'm using the PXI versions of your chassis and controller). Where are you located? Sometimes these things are simpler to do "over the phone" ...
