How Do I Set the Date and Time on a Remote Target in Measurement & Automation Explorer (MAX)?
Hello
I am trying to follow the steps in the following link:
It says
The software on the target currently support setting only the time zoneand delet old files?
I need to set the current date and time
and delete all old unwanted file
the calender was dimmed does not allow me to change the current date.
any one knows how to change it
Message 1 of 9
(7,240 Views)
Did you follow the rather complete description of this problem and how to fix it shown in MAX (and on the image you attached), namely going to ni.com/info and putting in the code MAXDateTime?
Message 2 of 9
(7,230 Views)
Yes
I did
But did not work
Message 3 of 9
(7,227 Views)
So please provide more information.
  • What version of MAX are you running?
  • What version of LabVIEW are you running?
  • What version of LabVIEW Real-Time are you running?
  • What version of System Configuration are you running?
  • What version of System Configuration Remote Support are you running?
  • Can you find your target in MAX?
  • Is the Time Settings Tab for the PXI present in MAX?
  • Did you try to set the time programmatically?
Message 4 of 9
(7,223 Views)
What we did for our cRIO-9076 is set it up to use an SMTP server to update the time.  So I don't worry about setting the time through MAX.
Message 5 of 9
(7,219 Views)
Hello Bob
Thank you for your reply
Here are the information you requested:
  • What version of MAX are you running?      15.3.0f0
  • What version of LabVIEW are you running?     15.0.1 (32 bit)
  • What version of LabVIEW Real-Time are you running?    15.01
  • What version of System Configuration are you running?    15.3.0f0
  • What version of System Configuration Remote Support are you running?    I can not find?
  • Can you find your target in MAX?  yes
  • Is the Time Settings Tab for the PXI present in MAX? I do not have PXI
  • Did you try to set the time programmatically? yes but did not work, I mean the date and time did not chang after running the seytting vi
Best regards
Ihab
Message 6 of 9
(7,191 Views)
hello Crossrutz
But could you tell me how ? I mean waht are the steps?
Best regrads
Ihab
Message 7 of 9
(7,189 Views)
Oops, sorry, I didn't notice you were working with a cRIO.  The "fix" that NI suggested mentioned PXIs, I've done this successfully with my PXI, so I (carelessly) assumed that you also had a PXI (I didn't look carefully enough at your original picture).  I hope that Crossrulz's suggestion will work for you (I'm sure he'll provide details ...).
Message 8 of 9
(7,169 Views)
Accepted by topic author Ihab
Hello Everyone!
According to this Knowledge Base article below, the System Configuration Remote Support needs to be installed on the target for the time settings to be changed in MAX.
http://digital.ni.com/public.nsf/allkb/FAB0EC4D6E5EE0F386257738005733A3?OpenDocument&metc=max_MAXDat...
If you do not know which version of the System Configuration Remote Support software you have installed on your target device, it is likely that it is not installed yet. Add this software by right clicking the software option below your target in MAX and selecting "Add/Remove Software." This is where you will install the System Configuration Remote Support software.
Please let us know if you have any questions!
John H.
Applications Engineering
Message 9 of 9
(7,123 Views)
