Property node - setting custom time?
Dear Ben and Friends,
can you pls post the working version of my vi , I simply can`t find the difference...
I really need this help guy I spent 2 days on this problem and I still don`t have a solution..
pls help
very best regards
john
Message 11 of 23
(1,582 Views)
i think i understood your problem.
1) do not set the x scale to autoscale
2) transform the chart to a waveform chart.
3) insert the 3 arrays into waveform where you can set intial time and dt.
here t0 is actually your output time stamp.
play!
Message Edited by Gabi1 on 12-04-2007 10:16 AM
... And here's where I keep assorted lengths of wires...
Message 12 of 23
(1,576 Views)
would you pls post your vi ?
Message 13 of 23
(1,569 Views)
Hi Ravens Fan,
yes I want 10:30:15 , for me it doesn`t matter which custom time I should set fro the beginning of X-axis since each time I will have another string with different times. And also each time the sampling rate will change through a string ( e.g 10  = 10 samples per second)
My ctrl-H is always on.
Do you need to use all of the string functions and date/time manipulation?  You could also put in a time stamp constant and select the correct date/time you want to use.  Convert it to double (Numeric/conversion palette) and wire that into those nodes.
how can I do that ? can you maybe post a vi ? I have LV7.1
thank you very much
Message 14 of 23
(1,567 Views)
my version now is 8.2, and dont have 7.1 installed on this computer.
just try to locate the elements i show in my pic, ( in waveforms...), and apply the scientific method 🙂 (try, look for your problems, define your goals, try again, check where it fault...)
As Ben Mentionned there are quite a bit of helpers in LV, like temporary indicators, highlighted mode runing, probes and pause at specific positioins.
Message 15 of 23
(1,557 Views)
I don't have 7.1 installed anymore.  But here is a screenshot of the code.
Message Edited by Ravens Fan on 12-04-2007 10:25 AM
Message 16 of 23
(1,549 Views)
would you post it still with LV 8.2 version?
my friend will downgrade it for me to LV 7.1 thnx
Message 17 of 23
(1,536 Views)
pls see the lastest version of my code, you will see what problem I face.
your solution is nice but in my case it is "string" and I converted to time format which is problematic.
pls just have a look
indeed you can modify if you know the solution
best regards
john
Message 18 of 23
(1,533 Views)
gabi , pls see my code, you will see that some how date to sec function doesn`t work !
Message 19 of 23
(1,532 Views)
John,
Please run your VI and take a look at what is displayed in the indicator labeled "output cluster".
There is an important hint in that indicator that will tell you why you are having trouble.
Ben
PS: I am here to teach and learn. Re-writng your code for you teaches both of us nothing. Please find the problem yourself and post back showing that you have fixed it or have tried.
Message 20 of 23
(1,525 Views)
