キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Formatting text string into correct columns
Greetings,
I am able to read data from a text file and to remove the comma for each data point using a While Loop, this part works. Now I need to acquire the first 0-9, 10-29, and then 30-49. 0-9 are columns, so under the first column is 0,10, and 30; the second column would be 1,11,31; etc. Does anyone know how to separate this so that I can plot the first column, the second column, etc?
Thank you for your help,
PIC
0 件の賞賛
メッセージ1/4
3,019件の閲覧回数
PIC,
Depending on the form of your data, you may not need to do a lot of rigorous parsing work at all.  Look at Read From Spreadsheet File.vi, Reshape Array.vi, and the Index Array.vi to extract your columns.
-cb
0 件の賞賛
メッセージ2/4
3,014件の閲覧回数
i think this is what you want........スマイリー ウインク
すべてをダウンロード
0 件の賞賛
メッセージ3/4
3,011件の閲覧回数
Thank you for your suggestion. It has lead me to other avenues to explore.
Thanks again
0 件の賞賛
メッセージ4/4
2,972件の閲覧回数
