Programmatically set bounds size of booleans in a 2D array control ?
I have a 2D array of boolean buttons.  Is there a way to programmatically set the size of the buttons (their Height and Width Bounds) ?  The Array property node (under Array Elements > Bounds) is read-only.
Steve
(3,849 Views)
You should be able to select Change to write
(3,837 Views)
hello Steve,
If you create a property node for the boolean control ( and not the array), you can find one called "button size".
See the attached pic for more help.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,837 Views)
And for yet a third method
Message Edited by Ben on 08-20-2007 12:05 PM
(3,825 Views)
Thanks to all.
I noticed that the boolean's Decal size does not scale with button size.  It seems to remain a constant rather than being proportional to button size (as it is if an individual buton is resized).  I do not see a Decay property.
Also, is there any way to have different boolean text on each individual boolean button within the array cotnrol ?
(3,803 Views)
No, an array is a set of identical objects, differing only in their value and identified by their index(s).
Message Edited by altenbach on 08-20-2007 12:08 PM
(3,800 Views)
