12-28-2010 01:20 PM
Hi I added a terminal to a sub vi (trying to add an input terminal to accept a string input). When I display the context help the terminal shows up with a pink wire but when I select the sub vi in the block diagram the new terminal does not show up so it is not possible to add the correct input. the subvi is used in several places and the program will not run until I add the string input to each location the sub vi is used.
Thanks.
12-28-2010 01:28 PM
12-29-2010 01:57 PM
that worked! I have a subvi within a subvi and I need to make an enumeration input of the inner vi accessable when the outer subvi is used. Any suggestions on how to set this up? thanks.
12-29-2010 02:04 PM
