Parts of block diagram can not be modified Labview RT cRIO 9065
I have to reprogram software on our cRIO-9065. However when I try to modify one of the SubVIs on the RT i encounter following issues:
1)  some branches can not be deleted. I click on it, then select: Delete Wire Branch and nothing is happening. Branch is still there
2)  I realized that on the coroner of some loops inside the project there is a padlock icon - see attachment - I tried to google it, but without success.
Please let me know if you encounter such issues before and how i could try to fix it.
Jan
(2,436 Views)
Somebody doesn't want you messing with it.
Bill
CLD
(Mid-Level minion.)
(2,410 Views)
Hi Folks,
i am working on an old software that was written on the cROI. Some of the loops have this strange padlock symbol in the corner. could you let me know what does it mean? i
Best,
Jan
(2,427 Views)
I already TOLD you what it was in your other post.  It's not going to change if you post again.  😉
Bill
CLD
(Mid-Level minion.)
(2,397 Views)
Dear Bill,
thank you very much for your involvement in my issue, but i would really appreciate technical answer instead of:
''Somebody doesn't want you messing with it''.
Thank you,
Jan
(2,390 Views)
I haven't see that either, but you also give very sparse information except for a blurry picture.
  • Do you know who wrote the VI? Is it part of some driver package?
  • You mention "old". How old? What LabVIEW version was used to write this?
  • What is your current LabVIEW version?
  • Do you have all the required modules in addition to plain LabVIEW (e.g. RT, FPGA, etc.)
  • Do you get any special context help when hovering over the structure?
  • Does the Vi currently work correctly? (i.e. not broken)
  • etc.
(2,373 Views)
LabVIEW DSC (and possibly other tools such as the State Diagram Toolkit) used to have wizards that could create code that was either connecting a control to a Tag variable or a graphical state diagram. Such code was locked to the wizard definition and as long as it stayed locked you could edit the code through its associated wizard configuration.
There should be a right click menu selection to unlock the structure. Once you do that the wizard configuration is lost and you can’t go back and configure it through the wizard mechanism.
Rolf Kalbermatter  My Blog
(2,349 Views)
