Parallel Generation and Acquisition
Hi.i'm using cRIO with NI 9215 and 9263 modules.
I want to know if it is possible to make in a single VI generation and acquisition in parallel using a FIFO local for the generation and a FIFO DMA for the acquisition.
I've seen a lot of posts of other people but as i've understood nobody has made it to work. Ca you give me some suggests?
Tnx a lot.
(4,152 Views)
Please DONT start seperate threads for the same requirement. Smiley Mad
- Partha ( CLD until Oct 2027 🙂 )
(4,141 Views)
sorry was my foult because my pc was disconnected by internet while i was posting and i've supposed that it doesn't send the post.
sorry again.
(4,138 Views)
hi Martin,
U need not apologize too much Smiley Sad, just keep in mind n make sure... Smiley Wink
(4,129 Views)
Hello martinmistere,
I am not sure if I have well understood your problem: have you already taken a look at the following documents?
Using DMA FIFO to Develop High-Speed Data Acquistion Applications for Reconfigurable I/O DevicesUsin...
DMA Improves LabVIEW FPGA 8.0 Throughput by 20X [broken link removed]
They explain how to use DMA transfer method into a FIFO architecture. Also, what do you mean with "FIFO local" ? I guess it could be the local FPGA onboard memory.
Hope this helps
best regards,
Fabio
Fabio M.
NI
Principal Engineer
(4,102 Views)
Martin,
Please take a look at this example [broken link removed] posted on DevZone.
(This was just added today, so you could not have found it before.)
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(4,097 Views)
