Opening an Executable(exe) file created by LabVIEW on remote PC
I intenend to run an executable (exe) file created in LabVIEW on remote PC from my local PC.Can anyone help me with this? I am able to run the VI remotely but have no idea of running an exe file remotely.
-Parag D
CLAD
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 1 of 48
(6,274 Views)
Hi Parag
The best way to achieve this is to use the active X server to start the executable. If you are running windows on both machines then have a look at this knowlede-base for some Ideas.
http://digital.ni.com/public.nsf/allkb/38787589F325412186256DE100671A8E?OpenDocument
best regards
Graham Green
Software Product Marketing
NI | Emerson
Message 2 of 48
(6,221 Views)
The link you provided was for a VI and not for an .exe file. Please help me to run .exe file. I have already opened the VI as explained in the link you posted.
Thanks a lot!
-FraggerFox!
Message 3 of 48
(6,217 Views)
I haven't tried downloading it yet, but the web page you cites says that the code is written in LV 5.1. Can current versions of LV even open V5.1 VIs? Or is the web page incorrect?
Mike...
LabVIEW Champion
Message 5 of 48
(6,200 Views)
I'm not sure about the security issues but is there a way that you could do it just using the command prompt. ie. "system exec.vi" ?
Best regards
Graham Green
NI | Emerson
Message 6 of 48
(6,195 Views)
Isnt there any way to run the labview exe on windows xp other than windows NT system?
-FraggerFox!
Message 7 of 48
(6,165 Views)
Can you explain that question more clearly?  Windows XP and NT are two different operating systems.  You have one or the other.  (Actually XP is a much later version based on NT)
Message 8 of 48
(6,163 Views)
I have Windows XP installed but the link which was given above for dcom configuration states that running an executable remotely is only supported on Windows NT.
-FraggerFox!
Message 9 of 48
(6,160 Views)
Hi Mathan,
Can you mail me to parthabe@rediffmail.com for further offline discussion?
- Partha ( CLD until Oct 2027 🙂 )
Message 10 of 48
(6,145 Views)
