‎12-20-2008 05:10 AM
I intenend to run an executable (exe) file created in LabVIEW on remote PC from my local PC.Can anyone help me with this? I am able to run the VI remotely but have no idea of running an exe file remotely.
-Parag D
CLAD
‎12-22-2008 05:25 AM
Hi Parag
The best way to achieve this is to use the active X server to start the executable. If you are running windows on both machines then have a look at this knowlede-base for some Ideas.
http://digital.ni.com/public.nsf/allkb/38787589F325412186256DE100671A8E?OpenDocument
best regards
‎12-22-2008 05:32 AM
The link you provided was for a VI and not for an .exe file. Please help me to run .exe file. I have already opened the VI as explained in the link you posted.
Thanks a lot!
‎12-22-2008 05:51 AM
‎12-22-2008 07:11 AM
I haven't tried downloading it yet, but the web page you cites says that the code is written in LV 5.1. Can current versions of LV even open V5.1 VIs? Or is the web page incorrect?
Mike...
‎12-22-2008 07:36 AM
I'm not sure about the security issues but is there a way that you could do it just using the command prompt. ie. "system exec.vi" ?
Best regards
‎12-22-2008 10:32 PM
‎12-22-2008 10:35 PM
Parag D wrote:
Isnt there any way to run the labview exe on windows xp other than windows NT system?
Can you explain that question more clearly? Windows XP and NT are two different operating systems. You have one or the other. (Actually XP is a much later version based on NT)
‎12-22-2008 10:37 PM
‎12-23-2008 04:40 AM
Hi Mathan,
Can you mail me to parthabe@rediffmail.com for further offline discussion?
