Open content-tree from chm-file (help) programmatically
actually I "try" to create a documentation for my software-tool with a *.chm-file (standard help-file).
I want, that the user can jump directly to the correct position in the content-tree like in the picture attached (not index-register).
First try with "Control online help.vi" doesn`t work respectively I use it in the wrong way.
So my question: is it possible with Labview to open a entry in the content-tree?
Thanks!!!
Message 1 of 13
(3,264 Views)
If you know the URL of the item, it shouldn't be hard.
Right click on the content item, you should get a URL like:
mk:@MSITStore:E:\Projects\help\MyCHM.chm::/Topics/Main/Item.html
Of course, if you've build the chm, you would be able to predict the URLs in a more systematic way (e.g. you shouldn't have to right click to get URLs).
If you use the Control Online Help function, wire the part after :: to the key, the path to the path, and the help should open (or jump to) with the context.
Message 2 of 13
(3,240 Views)
Thanks wiebe,
I use the only simple freeware-tool I found named Helpmaker. Its not supported since years.
I found the Url´s in the CHM-file and the correct side will open. But the content-tree will not expand...Do you have an idea, how this works?
Message 3 of 13
(3,222 Views)
@Tanchris wrote:
Thanks wiebe,
It should (it does for me) when I use the function's 'Key' option...
It could be something specific to your chm file, but we'd need that file (or a mockup) to examine it.
Message 4 of 13
(3,207 Views)
Thanks and thats right...
Here is the chm-file for testing...please don't wondering, I`ve tried out a lot since yesterday...
Message 5 of 13
(3,194 Views)
Hmm.  I don't get a URL when I right-click:
Message 6 of 13
(3,175 Views)
I got the Url when I press the "?" in the upper left corner und click "jump to url" (see attached file...)
As example like this: mk:@MSITStore:C:\01_Software\01_Testbench\documentation\helpTestbench\_tmphhp\helptestbench.chm::/konfigurationprüfen.html
Message 7 of 13
(3,158 Views)
This opens the DCU characteristics page (I got the URL by right clicking the page, then properties):
This opens the DCU characteristics page, and selects the item in the content tree:
Message 8 of 13
(3,152 Views)
Me neither in this chm file...
Message 9 of 13
(3,149 Views)
Thats exact what I´m looking for...but when I start the att. vi...only the correct right page will load, not the tree...
Message 10 of 13
(3,140 Views)
