One pixel frame for picture control
Hello
How can I create a picture control with a frame of one pixel (instead of 3 pixels by default)?
I would like it to look similar to a Classic Boolean Flat Square Button.
And if possible it would be nice to be able to change the color of this frame with the brush or a property node.
Thank you
Message 1 of 11
(5,765 Views)
Place down the Classic boolean.
Customize it.
Change to customize mode.
Show parts window and select the border.
Copy it to the clipboard and close editor.
Place down a picture control and customize it
Show the parts window and again select the border.
Right click it and Paste from Clipboard at same size.
aputman
Message 2 of 11
(5,746 Views)
APutman --
     I was about to give your post a Kudo (I'd looked at this, briefly tried to Customize the Control, quickly abandoned the attempt, but said "Glad someone figured it out!"), but decided to test it first.
     Getting the 1-pixel border from the Classic Boolean Control is easy (and an elegant idea!).  However, when I placed a 2D Picture Control (from LabVIEW 2016), there was no "Customize" setting that I could find.  I don't have 2012 on my laptop -- is this something that "used to be there", and now isn't?  Or am I just being foolish/forgetful?
Message 3 of 11
(5,703 Views)
I can customize the 2D Picture control and I have access to the part named "Frame".
However I did not manage to extract the frame of the Classic Boolean Flat Square Button, when I customize it I have only one part.
LabVIEW 2016
Message 4 of 11
(5,685 Views)
Bob,
I was having a similar problem (the customize option was greyed for me...in the advanced submenu) until I realized that the customize window was already opened for another control.  Apparently you can only customize one control at a time.
awilliotAcutronic,
Yes there are only two parts on the flat boolean and that is the part that you want to use.  I've attached my version of the control.  You may need to play with the dimensions of the Picture Area part because it is currently sized for a thicker border.  With a 1px border in the same location, there is a small 3-5px white "margin" around the control where you can't draw anything.  You can see it in the upper left corner of this screenshot.
aputman
Message 5 of 11
(5,679 Views)
@aputman:
Use a frameless Picture ctrl, add a decor frame won't have this problem.
George Zou
Message 6 of 11
(5,665 Views)
Never heard of a frameless Picture Control.  In LabVIEW 2016 (my current "working" version), I can't find it, only the 2D Picture Control (under Graphs) which has the 3-pixel frame "built-in".  Also, I just found that "Customize" now is not grayed out (thanks, aputman) ...
Message 7 of 11
(5,651 Views)
It's not shipped with LabVIEW.
I forgot where I downloaded it.  Probably from UI Interest group.
It was used in a 2D array of Picture ctrls to create a mosaic picture.
George Zou
Message 8 of 11
(5,646 Views)
On the FP....
Classic >>> Classic Graph >>> Controls >>>
Selecta 2d Picture
Switch to the paint brush and while over the border select the "T" for transparent.
That will give you a borderless picture indicator.
Ben
Message 9 of 11
(5,643 Views)
Very clever -- I didn't think about "Transparenting" elements I couldn't edit ...
BS
Message 10 of 11
(5,638 Views)
