Need help figuring out ListBox Ref producing a 1055 Error out of a property node
Hi Greg,
No, when running the .exe, I am getting an error "267" which pointed me to SystemExec, which is when I found the 1055 error being fed into it.
Message 11 of 26
(1,512 Views)
When you see error 1055, are you running Main.vi or just Download BGM111.vi?
Message 12 of 26
(1,510 Views)
It looks like error 267 can be related to an invalid "working directory" for system exec, and your python file paths change when running an executable. When you run your exe, it looks like your python files should be in this directory: "C:\Program Files (x86)\OEM Controls\BT-Tracker Downloader\Python"
Does that path exist on your machine?
Message 13 of 26
(1,507 Views)
If you run Download BGM111.vi by itself, you will get the error 1055 because the input reference is invalid. I see nothing in the hierarchy of the code that would result in that reference being invalid when run via the Main VI.
I suggest commenting out the Add Standard Listbox Message.vi calls within Download BGM111.vi, specify the 'Target' and 'Software File Paths' values in the Settings cluster that would normally be specified when running the Main VI, then run Download BGM111.vi by itself and debug from there. I think Gregory is on the right track with checking the validity of the paths to the python files.
Message 14 of 26
(1,498 Views)
Just the DownloadBGM111 or a Sub.vi therein.
Message 15 of 26
(1,488 Views)
Yes, that's what I thought, but that exact path is indeed on the machine.
Message 16 of 26
(1,487 Views)
OK Darren, I will try that & report back.
I thought that when you reply to a post here, the reply would appear under the post, so please excuse my last 2 posts which were replies to earlier replies.
Thanks again guys!
George
Message 17 of 26
(1,486 Views)
Accepted by topic author gsrokmix
That is why the listbox reference is invalid, it gets fed in from Main.vi. So, the original question is solved, but we still have to figure out why the System Exec is not working.
Similar to what Darren said, you can disable the listbox stuff, set reasonable values for "Settings in", and then test out the path that will be used when running the executable or when running the code in the development environment. You can try something like this in DownloadBGM111.vi:
Message 18 of 26
(1,481 Views)
Ok Greg, I will try that & let you know what I find.
Thanks so much!
George
Message 19 of 26
(1,477 Views)
OK, so after making the changes above, re-building the .exe, and running on the production machine with the hardware it looks like the SW is now downloading to the MCU!
I will see if the rest of the test works and report back...........fingers crossed......................
George
Message 20 of 26
(1,417 Views)
