Need help figuring out ListBox Ref producing a 1055 Error out of a property node
Hi George,
The point of making those changes is so that you could debug in the development environment. I'm really baffled that the executable would behave differently. Were you running an executable on a production machine when you first started receiving error 267?
Message 21 of 26
(916 Views)
Hi Greg,
Yes, we were getting the "267" error running the .exe on a run-time machine. I am having a few other issues regarding hardware I/O, and am re-building the .exe now to continue testing.
George
Message 22 of 26
(910 Views)
So the original issue I was having with the Python script is now working fine. I am having some other small issues with the test app, but this issue has been solved.
Thanks very much for the invaluable help!
George
Message 23 of 26
(861 Views)
Hi George, how did you fix the issues with the python scripts? Did you just disable the listbox properties, or did you have to put the files into an expected folder, or something else?
Message 24 of 26
(855 Views)
Hi Greg,
I just disabled the List Box properties, and then the script loaded & ran just fine.
Thanks again for all of your help!
George
Message 25 of 26
(842 Views)
Wow... that still baffles me!
Message 26 of 26
(835 Views)
