NI Scope and DAQmx synchronization
Hi everyone,
i'm triyng to set up a synchronized acquistion system composed by a pxi 5122 and a pxi 6133 boards. The system should be configured to get a trigger on the pxi5122, export it to the pxi6133 and perform a simultaneous acquisition of the two boards. Unfortunately, the settings i use (ConfigAcq.vi is the vi though wich the boards are configured) are not working, since after few minutes of acquisition i get a Error-200284, wich cause the whole program to crash. The acquisition is performed in the timed loop represented in AcquisitionPicture.png.
I think some setting is incorrect, but i cannot figure out where nor what has tho be changed.
Thank you for your help!
Mattia
(2,760 Views)
Hi Mattia,
The Labview Error-200284 is product of: Some or all of the samples requested have not yet been acquired. So,try to check:
1) Sample rate
2) Timing and trigger configuration.
I hope this will be helpful for you.
Andres
Andrés Alvarez
Staff Technical Support Engineer
CLD, CTD, CTA
(2,719 Views)
 Hi Mattia,
Did you solve the problem?
Andres
Andrés Alvarez
CLD, CTD, CTA
(2,690 Views)
