02-10-2012 12:25 AM
I got 4 cds of NI Developer Suite 2011, version DS2; But when I installed it, it paused after DVD1.
First, I checked many options, such as RT module, FPGA moudle, after DVD1, a message popped up said DVD2 should put in.
I followed the message, put DVD2 in, then the installation procedure puased for 1 hr.
Later, I tried to reinstall the developer suite 2011, I only checked labivew core and meaurement studio 2010, and communicaiton option: labwindows CVI modulation , labwindows CVI spectruam module. This time, after DVD1, it showed DVD3 was needed. When I put DVD3 in, the installation paused too.
I don't know why it is so difficult to install NI developer suite 2011, I need help.
03-02-2012 07:44 AM
I have found the full developer suite does take a very long time to install (several hours) with the disk swaps, I can only advise patience. If something is going wrong it will generally tell you in no uncertain terms
TD
