NI Developer Suite 2011 DS2 installation problem
I got 4 cds of NI Developer Suite 2011, version DS2; But when I installed it, it paused after  DVD1.
First, I checked many options, such as RT module, FPGA moudle, after DVD1, a message popped up said DVD2 should put in.
I followed the message, put DVD2 in, then the installation procedure puased for 1 hr.
Later, I tried to reinstall the developer suite 2011,  I only checked labivew core and meaurement studio 2010, and communicaiton option: labwindows CVI modulation , labwindows CVI spectruam module. This time, after DVD1, it showed DVD3 was needed. When I put DVD3 in, the installation paused too.
I don't know why it is so difficult to install NI developer suite 2011, I need help.
(2,812 Views)
I have found the full developer suite does take a very long time to install (several hours) with the disk swaps, I can only advise patience. If something is going wrong it will generally tell you in no uncertain terms
TD
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,732 Views)
