Multiple cluster type def not updating
I have the tab controls in my cluster, because I use it in my main program, and I would like to save the tab selected in the cluster.
Kudos and Accepted as Solution are welcome!
Message 11 of 28
(1,796 Views)
Accepted by jyang72211
The tab controls are very similar to enums so try using an enum instead of the tab control.
Re: the BUG
Yes, the type def is failing to update and the only work-around I could find was to toss the tab controls. I'll try to get an App Engineer to look into this but I can confirm the bug.
Thanks for sharing!
Ben
Message 12 of 28
(1,790 Views)
I do not like them tabs
Maybe they will work someday.
'nuff said.
"Should be" isn't "Is" -Jay
Message 13 of 28
(1,777 Views)
How did you even get the tab control inside the cluster? That's not supposed to be allowed, and is quite possibly the source of your problem.
___________________
Try to take over the world!
Message 14 of 28
(1,767 Views)
cite source please
Message 15 of 28
(1,764 Views)
I knew they looked strange in the cluster but failed to recogize htat as being illlegal.
I am alos curious how it was done since I can't trick LV into letting me repeat that feat.
Jyang,
Can you give us a clue?
Ben
Message 16 of 28
(1,760 Views)
I'd also be interested in knowing how this was done. There is some good discussion as to why this isn't a feature of LabVIEW in this thread
Applications Engineer
CLD Certified
Message 17 of 28
(1,756 Views)
@JÞB wrote:
cite source please
If Zach's link wasn't enough for you, you can also turn to LV itself - try to do in manually and it won't allow it. Try to do it programmatically and you get error 1060 - Object cannot contain (own) the specified object. I think that's pretty authoritative.
P.S. Personally I wouldn't mind if it was allowed, although not for UIs - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-clusters-to-have-quot-pages-quot/idi-p/1481862
___________________
Message 18 of 28
(1,750 Views)
I make the tab control into a type def and put it into a type def cluster.  I am not sure can I repeat this, but that was what I did.
Message 19 of 28
(1,744 Views)
Did you by any chance do that in an earlier version of LV?
I tried that as well and could not get it into the cluster.
Curious,
Ben
Message 20 of 28
(1,739 Views)
