Multiple Choice Quiz
i want make quiz like " who wants to be a millionaire " where each answer button has text, and one of them is correct answer, when the question changes, text on the question button change as well.
anyone can help me ?
(3,826 Views)
You can use the property nodes of the buttons to change the text.
Thanks & Regards,
Bharath Kumar
GCentral
(3,801 Views)
Generic questions will get you generic answers...
Answers like "use a state machine".
You need to be a bit more specific on the problems you run into.
(3,795 Views)
Thank you for your advice, but I need some help to do this whole program because I'm a beginner and I don't know how to do it
(3,794 Views)
Start with the (free) courses.
Start (in parallel) with a design (and clear requirements).
After you did the courses, start looking into architectures.
(3,777 Views)
Although I am all for challenging yourself to learn, you probably bit off more than you can chew.  I'd start with something a little simpler.  Something to show yourself you understand the basics.  This is a little like trying to learn guitar solo when you should be learning chords first.
Bill
CLD
(Mid-Level minion.)
(3,734 Views)
