11-26-2019 09:14 AM
I would to command my z_axis by using serial communication. I put the command which allows to move the axis in the string for visa write but when I execute the programm my axis didn't move.
I respect the baud rate for my printer, the command is in G-code.
Can you help to know where is the mistake, I can't see it.
Thank you,
11-26-2019 09:21 AM
My first guess is that you needed a termination character such as a carriage return or linefeed at the end of the string.
Do you really want to run that same command over and over again in a loop as fast as the CPU will allow? You should probably have that run only once. Or be a part of an event structure so that it only runs when you press a button.
11-26-2019 09:33 AM
I added your remark, but it doesn't work.
11-26-2019 09:37 AM
No. You added a literal backslah and "n" to the message. You need to put that string constant into \code display (and make the display style visible), then enter \n.
And you didn't do what I said with the event structure. You put it in a timeout case, and there is no timeout value so it will never run. I said use a button. If you create a value change event for that button, you can put it in a loop and it will execute every time you press the button.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
11-26-2019 09:43 AM
I don't understand what you said here:"You need to put that string constant into \code display (and make the display style visible), then enter \n."
You mean I should write: "G1 Z-0.005" \n ?
11-26-2019 09:59 AM
I did thes modifications, I understand what you said. Can you tell me if that you would like to say?
11-26-2019 12:18 PM
Nope. Still a lot to fix.
See the modifications and the notes.
11-27-2019 05:36 AM
Thank you for your answer, I tried the programm but it doesn't work, the z axis didn't move.
11-27-2019 07:25 AM
Without seeing what your latest code is, knowing what the device is, or having any access to a similar device of my own, I can't provide anymore help.
I suggest you dig into the manual.
11-27-2019 07:57 AM
I used the same programm that you sent me, the machine is printer 3D.
