Controlling BSC203 (thorlabs) using LabView
Greetings,
I am trying to control BSC203 (from thorlabs) using Labview 2019. I followed the steps presented in this guide (https://www.thorlabs.com/images/TabImages/GuideToLabVIEWandAPT.pdf) and I created my own VI (attached as image).
The problem is that when labview runs `MoveHome´ method, the following error appears: "FT_IO_ERROR. A USB communication problem has occurred with this controller. Communication to this controller is suspended. The software should be closed and the controller powered off and on to try re-establishing USB communication." (window attached).
Moreover, motor spins and doesn't stop (I had to turn off BSC203).
I got to communicate with the stepper controller (because if I change `MoveHome´ method to `Identify´ method, green led starts to blink) and I ran the same VI but with LTS300 (changing serial number) and it worked properly (I am not using both at the same time, I swapped the USB connection).
I suppose that I am employing the correct ActiveX Control (MG17Motor) because it is the one that the stepper controller user guide mentions.
I would appreciate any help that you can give me. I asked thorlabs too.
Thanks in advance!
(3,274 Views)
I got the same message here with a TST001 Controller, even when using Thorlabs motion control kinesis software or Thorlabs apt user software.
USB Comms Error
A USB communications error has occurred.
Did you manage to solve it?
Thanks in advance.
(3,155 Views)
