Moving columns of one array
Hi everybody,
In four firsts columns i've value of voltage and last four columns i've the date of acquisition. I need to move position of columns. The drawing below shows how it should be the final position of the array.
Thanks.
(4,266 Views)
@Carlos1987 wrote:
Hi everybody,
In first four columns I have value of voltage and last four columns I have the date of acquisition. I need to move position of columns. The drawing below shows how it should be the final position of the array.
Thanks.
Selectively use the array manipulation functions to break apart the array and rebuild the columns in the order you want.
Index Array, Build Array,
Delete from Array, Insert into Array,
and also Array Subset can all be used.
There are a number of ways to do it.  I would use Array Subset to get the different sections, and then use Build Array to put them back together.
(4,254 Views)
Accepted by Carlos1987
Hi Carlos,
I've taken a look at your VI and I think the solution to the problem is the first snippet.  But then again I was thinking why you do it that way.  So I programmed it differently and that is shown in the second VI.  The second one should be a lot better then the first one.  Probably not even the best way to do it, but it's programmed in 5 secs 😉
WrongWayBetterWay
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(4,235 Views)
What's the purpose of the 0ms wait in the innermost loop???
(4,233 Views)
Hi Altenbach,
No idea - has no use at all - but I kept it in there 😉
Kind regards,
- Bjorn -
(4,228 Views)
This my mistake. SorrySmiley Happy
(4,198 Views)
