Labview 2016 - time error
Hi all, i'm new user of labview, and i'm having a problem.
I opened an example project: "NI-USRP Simple Streaming with USRP-2945/2955", and tried to run the FPGA vi.
When the compilation completed an error occurred:
I've found some questions about this exact problem and tried the following things:
-Compile with NI cloud server
-Different directory
-Build and download to FPGA separately
-Change the name of the vi
I own USRP-2955, PCIe-8371,
Windows 7, 64 bit, SP 1
Labview 2016, 32 bit
Thanks!
(4,190 Views)
IIRC, the USP needs a 100MB network adapter. Older laptops might have 10MB. 10 MB could be enough for the bandwidth, but the USRP simply won't connect. A 100MB hub between PC and USP will make it work if that's the problem. Or adding a 100 MB network adapter of course.
This was a while ago. The modern USRP's might even need a 1GB network adapter...
(4,168 Views)
Thanks for the answer.
The USRP connected to the computer threw PCIe-8371:
I don't think this is the problem..
(4,153 Views)
Yep, tried all of them.
Maybe there's a chance that some of the SCTLs' clocks in the fpga vi are not correct?
(4,125 Views)
Drawing blanks... Firewall is off?
(4,118 Views)
It's off
(4,114 Views)
