‎10-02-2017 01:49 AM
Hi all, i'm new user of labview, and i'm having a problem.
I opened an example project: "NI-USRP Simple Streaming with USRP-2945/2955", and tried to run the FPGA vi.
When the compilation completed an error occurred:
I've found some questions about this exact problem and tried the following things:
-Compile with NI cloud server
-Different directory
-Build and download to FPGA separately
-Change the name of the vi
I own USRP-2955, PCIe-8371,
Windows 7, 64 bit, SP 1
Labview 2016, 32 bit
Thanks!
‎10-02-2017 02:18 AM - edited ‎10-02-2017 02:20 AM
IIRC, the USP needs a 100MB network adapter. Older laptops might have 10MB. 10 MB could be enough for the bandwidth, but the USRP simply won't connect. A 100MB hub between PC and USP will make it work if that's the problem. Or adding a 100 MB network adapter of course.
This was a while ago. The modern USRP's might even need a 1GB network adapter...
‎10-02-2017 02:51 AM
Thanks for the answer.
The USRP connected to the computer threw PCIe-8371:
I don't think this is the problem..
‎10-02-2017 03:12 AM
Not sure if you already tried these:
‎10-02-2017 09:49 AM
Yep, tried all of them.
Maybe there's a chance that some of the SCTLs' clocks in the fpga vi are not correct?
‎10-02-2017 10:00 AM
Drawing blanks... Firewall is off?
‎10-02-2017 10:06 AM
It's off
