LabView Can't find connected instruments
Yes, I am aware of it but the LabView programs that I will be running are pre-written and include sub VIs that come with the drivers. I guess these programs wont run without the drivers then...will they !?
Thank you
Message 11 of 19
(1,594 Views)
Hi Abinash,
@AbinashB wrote:
I did go to NI instrument driver network and found the drivers for standford research 830 and keithley 2000 against LabView 18.0. But when i click on download, nothing happens !!
Read the informations of your webbrowser more carefully:
I can download the file - after allowing the download… (FF117.0.1, tested with SR830.)
Message 12 of 19
(1,592 Views)
Thank you very much...! that worked...this time I opened from a different browser and i could see a pop up...earlier there was no pop up..!!
Now that I have the files, I dont see any 'setup.exe' file to install....shall I just go paste these in instr.lib in program files\labview2018 ??
Message 13 of 19
(1,582 Views)
Accepted by AbinashB
Hi Abinash,
Basically yes.
The lvproj expects the files in this location:
(I used LV2019 to open the project.)
Message 14 of 19
(1,574 Views)
I pasted the folders in Program files\LabView2018\instr.lib and now they are showing in Instrument IO palette in LabView. But there are no subVI s that are listed there...!! i am attaching a screenshot showing that...LabView Inst IO shot.png
Message 15 of 19
(1,565 Views)
Hi Greg
Its showing now. The 'Keithley' and 'Standford Research' folders that i pasted had another folder with same name inside because they were extracted that way. Now I have pasted just the Keithley and SR folder with the necessary files. Thank you very much..!!
Best Regards
Abinash
Message 16 of 19
(1,565 Views)
Hi Abinash,
@AbinashB wrote:
Hi Greg
Who is Greg?
Message 17 of 19
(1,543 Views)
Sorry, i mistyped. Should have been GredW !! 😄
Message 18 of 19
(1,527 Views)
Hi Abinash,
Who is GredW?
Message 19 of 19
(1,520 Views)
