LabVIEW on core M processor
Hi everyone, I want to buy a lightweight and long battery life and i found a lot very good laptop with core M processors. But i doubt the performance of these CPUs. I am not a professional software guy but mainly focused on electronics and optics. Most of the time i use labview as a general programming tools to communicate with hard wares through serial port/spi/ethernet. sometimes i will do offline data processing like fitting/array processing. Is there anyone tried labview on laptops with core m cpu like asus ux305? is there any problem? thanks a lot!
(4,001 Views)
Accepted by Chengxian
It will install and run fine for light LabVIEW use, things will just take longer than if you had a more powerful machine - especially if you are doing a lot of data processing. Perhaps more importantly - if you are connecting hardware, you need to be aware of how many USB / Ethernet ports the laptop has. You'll need a USB port for a USB to Serial adapter and the UX305 doesn't look like it has an ethernet port so you would need a USB to Ethernet as well. Some USB devices don't play well with USB hubs either.
Personally as a LabVIEW professional, I wouldn't do any development on a laptop with anything less than an i5 processor, 8GB RAM. I would also prefer an SSD and an external monitor/KB/mouse. LabVIEW with a touchpad is not fun.
(blog)
(3,958 Views)
I have an old P3 256Meg RAM Windows XP system here in the lab that except for haveing to disable SSE extentions with building an exicutible, runs LabVIEW just fine.
Core M should be more than enough power
=== Engineer Ambiguously ===
(3,934 Views)
Thank you Sam! I will increase my budget a bit to get a better one.
(3,843 Views)
Thank you RTSLVU!
(3,842 Views)
