DATA LOGGING
Hello Everyone,
I have created a simulator having different parameters with graphs. This simulator is made under control and simulation loop. The problem i'm facing is as soon as i'm adding write data i/o block to this loop the system is showing the response in very slow manner. What can i do to maintain good speed and as well as log the data in control and simulation loop.
Thanks in advance
Viplav
(3,248 Views)
I'm almost certain I know the source of your problem -- you have a single While loop inside which you are trying to do too many things, some of which take time and "slow things down".  Of course, that's just a guess as you failed to attach your VI so we could see what you did, try to make improvements, and suggest "solutions" for you.
Do you understand the concept of Data Flow, one of the key concepts of LabVIEW?  You can take advantage of this to run two loops in parallel, potentially isolating the "slow poke" so that the "data producing" loop can run full speed.
Look up Producer/Consumer Design Pattern, see if this applies to your situation.  And post your code!  [This means "attach your VI" -- do not attach static pictures of all or part of your Block Diagram -- we can't edit or execute a static picture].
(3,220 Views)
Clear case of needing a Producer/Consumer architecture.  The idea is that you move your file IO into another loop so that your main loop can keep the rate it actually needs.  You pass data from the main loop (producer) to the file IO loop (consumer) with a queue.
(3,202 Views)
