LabVIEW.exe - application error
Hi.
I'm trying to use CIN to up-down flip a two dimensional array passed from LabVIEW.  Everything seems to work fine when I run the .vi (flipper.vi).  However, when I run another .vi (save_data.vi) that uses the flipper subroutine, it crashes LabVIEW.
Specifically, I recieve a LabVIEW.exe - Application Error:
The instruction at x-location referenced memory at y-location. The memory could not be "read".
Now I understand that somewhere along the lines LabVIEW accesses corrupt memory, due to a lack of array initialization or something. Unfortunately, that's about all I understand.
I'm using LabVIEW 8.0. Here is my flipper CIN code:
/* CIN source file */
#include <extcode.h>
/* stubs for advanced CIN functions */
UseDefaultCINInit
UseDefaultCINDispose
UseDefaultCINAbort
UseDefaultCINLoad
UseDefaultCINUnload
UseDefaultCINSave
/* Typedefs */
typedef struct {
    int32 dimSizes[2];
    int16 Numeric[1];
    } TD1;
typedef TD1 **TD1Hdl;
extern "C"{
MgErr CINRun(TD1Hdl dataIn, TD1Hdl dataOut);
TD1Hdl dataOut)
        int32 rowSize = (**dataIn).dimSizes[0]; // number of rows of data
        int32 colSize = (**dataIn).dimSizes[1];    // number of columns of data
        (**dataOut).dimSizes[0] = rowSize;
        (**dataOut).dimSizes[1] = colSize;
        // up-down flip of data
        int32 i, j, arrayIndex;
        for(i = 0; i < rowSize; i++)
            for(j = 0; j < colSize; j++)
                arrayIndex = colSize*i + j;
                (**dataOut).Numeric[arrayIndex] = (**dataIn).Numeric[arrayIndex];
    return noErr;
Let me know if you have any ideas on how to possibly initialize the data that I'm passing into the CIN.
Hopefully this makes some sense. Thanks,
(2,844 Views)
Hi, mrod,
The destination array should be resized before writing values with NumericArrayResize function:
The code above should work without troubles (hopefully).
best regards,
Andrey.
(2,824 Views)
Hi, Andrey.
The NumericArrayResize fixed the error I was getting. Thanks so much.
best regards.
(2,795 Views)
