Controlling power supply LV-application with other LV-applications
I have a small application that drives a power supply, it can regulate current and voltage.
This application has been build using the application builder and thus is an *.exe
Now I want wo write other stand alone applications with the builder, that can start and control
my power-supply program. Is this possible?
I can change the source-code of both programs, but when finished, I want to build them
with the application builder to get 2 stand-alone *.exe
Thank you very much for your time!
Heinen Smiley Happy
The Enrichment Center is required to remind you that you will be baked, and then there will be cake.
(2,808 Views)
Hi Heinen,
you can use TCP/IP functions to build a communication between your programs. See the shipped example to get more information about it.
Hope it helps.
Mike
(2,806 Views)
Hello Mike S81,
Isn't TCP/IP something that has to do with network communication?
I want to use my programs on the same pc.
Thx 🙂
(2,803 Views)
Hi Heinen,
yes that´s right, but you can use it also to communicate between programs on the same pc, and the advantage is, if you need to use it later on two pc´s it´s simply possible. Smiley Wink
Mike
Message Edited by MikeS81 on 06-30-2008 04:52 PM
(2,799 Views)
I don't really think you need to delve into using TCP/IP, as that would probably involve potentially considerable change to your code. I would suggest looking at using the VI Server capabilities first.
(2,790 Views)
